5+ years of slavishly following T-mag
LG Elf Ftr/Wizard 7/17
Re: 5+ years of slavishly following T-mag
Post by LG Elf Ftr/Wizard 7/17 » Thu Jan 08, 2015 5:33 pm
2 JAN: tennis for 75'
3 JAN: tennis for 60'
4 JAN: 158.5# hang clean/FSq, 12x3/5, 75s rests
5 JAN: tennis for 60', then
heavy bag work 2' rounds x9, 1' rests
7 JAN: tennis for 60', then
306# TBDL 12x3, 90s ints
Senator Ted Kennedy, just five years after Chappaquiddick (criticizing President Gerald Ford's pardon of Richard Nixon): "Is there one system of justice for the average citizen and another system for the high and mighty?"
Post by LG Elf Ftr/Wizard 7/17 » Wed Jan 21, 2015 7:46 pm
8 JAN: tennis for 60', then
70.5# DB C&PP, 9x6L/R, 1' rests
9 JAN: tennis for 60', then
10 JAN: tennis for 60'
12 JAN: 160# hang clean/FSq, 10x3/5, 75s rests
13 JAN: jump rope sprints 38sec/22sec rest x18
Post by LG Elf Ftr/Wizard 7/17 » Wed Jan 21, 2015 7:49 pm
16 JAN: tennis for 90'
18 JAN: tennis for 60'
19 JAN: tennis for 60', then
307.5# TBDL 12x3, 90s ints
20 JAN: 71# DB C&PP, 9x6L/R, 1' rests
21 JAN: heavy bag work 2' rounds x9, 1' rests
Post by LG Elf Ftr/Wizard 7/17 » Sat Jan 31, 2015 5:37 pm
22 JAN: tennis for 60'
23 JAN: tennis for 60'
24 JAN: tennis for 60'
26 JAN: 161# hang clean/FSq, 10x3/5, 75s rests
27 JAN: 71.5# DB C&PP, 9x6L/R, 1' rests
Post by LG Elf Ftr/Wizard 7/17 » Thu Feb 05, 2015 12:18 am
30 JAN: tennis for 90'
31 JAN: 162.5# hang clean/FSq, 10x3/5, 75s rest
2 FEB: tennis for 60', then
72# DB C&PP, 9x6L/R, 1' rests
3 FEB: tennis for 60'
4 FEB: 40kg KB 2HS/dips, 15x10/6, 90s ints
Post by LG Elf Ftr/Wizard 7/17 » Wed Feb 11, 2015 9:06 pm
5 FEB: tennis for 90'
7 FEB: tennis for 60', then
40kg KB 2HS 10x12, alternating with 72.5# DB PP 10x8, 75s ints
9 FEB: tennis for 60', then
163.5# hang clean/FSq, 15x3/3, 60s rest
11 FEB: tennis for 60', then
40kg KB 2HS/BW+10# dips, 17x10/6, 90s ints
Post by LG Elf Ftr/Wizard 7/17 » Thu Feb 19, 2015 11:05 pm
12 FEB: 60# 1HS, 15x10, 1' ints
14 FEB: 60# 2HS, 15x10, 1' ints
15 FEB: tennis for 60', then
40kg KB 2HS, 10x10, 1' ints
16 FEB: tennis for 60', then
165# hang clean/FSq, 15x3/3, 60s rest
17 FEB: tennis for 60', then
40kg KB 2HS, 11x10, alternating with 73# DB PP 11x8, 45s rests
18 FEB: 40kg KB 2HS, 12x10, alternating with pullups 12x5, 1' rests
Last edited by LG Elf Ftr/Wizard 7/17 on Fri Feb 27, 2015 5:44 pm, edited 1 time in total.
Post by LG Elf Ftr/Wizard 7/17 » Fri Feb 27, 2015 5:44 pm
19 FEB: tennis for 60', then
40kg KB 2HS, 12x10, 1' ints
21 FEB: tennis for 120', then
40kg KB 2HS, 12x10, alternating with 73.5# DB PP 12x8, 45s rests
22 FEB: tennis for 60', then
166# hang clean/FSq, 15x3/3, 60s rests
23 FEB: tennis for 60', then
60# 2HS, 20x10, 30s rests
24 FEB: tennis for 60', then
40kg KB 2HS, 12x10, alternating with pullups 12x5, 45s rests
25 FEB: 40kg KB 2HS, 10x10, 55s ints
Post by LG Elf Ftr/Wizard 7/17 » Wed Mar 04, 2015 6:44 pm
26 FEB: 40kg KB 2HS, 10x10, 55s ints
27 FEB: 167.5# hang clean/FSq, 15x3/3, 60s rests
1 MAR: tennis for 60', then
40kg KB 2HS, 12x10, alternating with 74# DB PP 12x8, 45s rests
2 MAR: tennis for 60', then
40kg KB 2HS, 12x10, 55s ints
3 MAR: tennis for 60', then
40kg KB 2HS, 13x10, alternating with pullups 13x5, 45s rests
4 MAR: 168.5# hang clean/FSq, 15x3/3, 60s rests
Post by LG Elf Ftr/Wizard 7/17 » Thu Mar 12, 2015 1:34 am
5 MAR: tennis for 60', then
6 MAR: tennis for 60'
7 MAR: tennis for 60'
8 MAR: 170# hang clean/FSq, 12x3/3, 60s rests
10 MAR: tennis for 60', then
heavy bag work 2' rounds x10, 1' rests
11 MAR: tennis for 60', then
171# hang clean/FSq, 12x3/3, 60s rests
Post by LG Elf Ftr/Wizard 7/17 » Wed Mar 25, 2015 8:33 pm
13 MAR: 40kg KB 2HS, 10x10, 1' ints
14 MAR: tennis for 60'
17 MAR: tennis for 60', then
18 MAR: tennis for 60', then
Post by LG Elf Ftr/Wizard 7/17 » Wed Mar 25, 2015 8:36 pm
19 MAR: tennis for 60'
20 MAR: tennis for 60', then
40kg KB 2HS, 15x10, 1' ints
24 MAR: tennis for 90', then
172.5# hang clean/FSq, 12x3/3, 60s rests
25 MAR: tennis for 90', then
Post by LG Elf Ftr/Wizard 7/17 » Thu Apr 02, 2015 10:32 pm
26 MAR: tennis for 60', then
40kg KB 2HS, 12x10, alternating with 75# DB PP 12x8, 45s rests
27 MAR: 40kg KB 2HS, 12x10, 1' ints
28 MAR: tennis for 60', then
40kg KB 2HS, 10x10, alternating with pullups 10x5, 45s rests
29 MAR: 173.5# hang clean/FSq, 12x3/3, 60s rests
30 MAR: tennis for 60', then
heavy bag work 2' rounds x8, 1' rests
31 MAR: 40kg KB 2HS, 10x10, 1' ints
1 APR: tennis for 60', then
Post by LG Elf Ftr/Wizard 7/17 » Thu Apr 09, 2015 11:21 pm
2 APRIL: tennis for 60', then
175# hang clean/FSq, 12x3/3, 60s rests
4 APRIL: tennis for 60'
5 APRIL: tennis for 60', then
40kg KB 2HS, 12x10, alternating with 76# DB PP 12x8, 45s rests
6 APRIL: 40kg KB 2HS, 10x10, alternating with pullups 10x5, 45s rests, followed by
heavy bag work 2' rounds x5, 1' rests
7 APRIL: tennis for 60'
8 APRIL: 40kg KB 2HS, 12x10, 55s ints
Post by LG Elf Ftr/Wizard 7/17 » Wed Apr 15, 2015 10:47 pm
9 APRIL: tennis for 60', then
176# hang clean/FSq, 12x3/3, 60s rests
11 APRIL: 40kg KB 2HS, 15x10, 1' ints
13 APRIL: 40kg KB 2HS, 12x10, alternating with 76.5# DB PP 12x8, 45s rests, followed by
heavy bag work 2' rounds x6, 1' rests
14 APRIL: 40kg KB 2HS, 16x10, 1' ints
15 APRIL: tennis for 60', then
177# hang clean/FSq, 12x3/3, 60s rests
Post by LG Elf Ftr/Wizard 7/17 » Wed Apr 22, 2015 9:47 pm
16 APRIL: 40kg KB 2HS, 12x10, 55s ints
18 APRIL: tennis for 150'
19 APRIL: tennis for 90'
20 APRIL: tennis for 60', then
40kg KB 2HS, 12x10, alternating with pullups 12x5, 40s rests
21 APRIL: tennis for 60', then
40kg KB 2HS, 15x10, 55s ints
22 APRIL: tennis for 60', then
178# hang clean/FSq, 12x3/3, 60s rests
Post by LG Elf Ftr/Wizard 7/17 » Thu Apr 30, 2015 7:00 pm
23 APRIL: 40kg KB 2HS, 12x10, alternating with 78# DB PP 12x8, 45s rests
24 APRIL: tennis for 75'
25 APRIL: tennis for 60', then
40kg KB 2HS, 10x10, alternating with pullups 10x5, 40s rests
26 APRIL: tennis for 75'
27 APRIL: tennis for 60', then
179# hang clean/FSq, 12x3/3, 60s rests
28 APRIL: 40kg KB 2HS, 12x10, alternating with 78.5# DB PP 12x8, 45s rests
29 APRIL: tennis for 60', then
bennyonesix
Post by bennyonesix » Thu Apr 30, 2015 7:05 pm
Did anyone actually play Lawful Good characters?
Maybe if I lost a bet or something.
Considering how much I cheated at the D&D it would be silly to have a LG character.
I was more a chaotic good kinda guy.
Post by LG Elf Ftr/Wizard 7/17 » Thu May 07, 2015 6:48 pm
bennyonesix wrote:Did anyone actually play Lawful Good characters?
You never once had a burning desire to be a Paladin? Actually I was trying to find a really lame username. I'm kind of proud of it.
Post by LG Elf Ftr/Wizard 7/17 » Thu May 07, 2015 6:54 pm
30 APRIL: tennis for 60', then
40kg KB 2HS, 12x10, alternating with pullups 12x5, 1' ints
2 MAY: tennis for 60'
3 MAY: tennis for 60'
4 MAY: tennis for 60'
Last edited by LG Elf Ftr/Wizard 7/17 on Fri May 08, 2015 5:49 pm, edited 1 time in total.
bennyonesix
Post by bennyonesix » Thu May 07, 2015 8:49 pm
It's fantastic, dude. I wish I had thought of it.
Post by LG Elf Ftr/Wizard 7/17 » Fri May 08, 2015 5:51 pm
Dude rolled a 20, no wonder he's so pumped.
Post by LG Elf Ftr/Wizard 7/17 » Wed May 20, 2015 6:42 pm
7 MAY: 180# hang clean/FSq, 12x3/3, 60s rests
8 MAY: tennis for 60', then
40kg KB 2HS, 12x10, alternating with 79# DB PP 12x8, 45s rests
9 MAY: tennis for 90'
10 MAY: tennis for 60', then
11 MAY: 181# hang clean/FSq, 10x3/3, 60s rests, then
12 MAY: tennis for 60', followed by
40kg KB 2HS, 12x10, then heavy bag work 2' rounds x6, 1' rests
13 MAY: tennis for 60'
Post by LG Elf Ftr/Wizard 7/17 » Wed May 20, 2015 6:47 pm
14 MAY: tennis for 60'
15 MAY: tennis for 60'
16 MAY: tennis for 120'
17 MAY: 40kg KB 2HS, 12x10, alternating with 80# DB PP 12x8, 45s rests
19 MAY: tennis for 60', followed by
180# hang clean/FSq, 12x3/3, 60s rests, then heavy bag work 2' rounds x6, 1' rests
20 MAY: 40kg KB 2HS, 10x10, alternating with pullups 10x5, 1' ints, then
Post by LG Elf Ftr/Wizard 7/17 » Sat May 30, 2015 8:00 pm
21 MAY: tennis for 90'
23 MAY: tennis for 60'
25 MAY: tennis for 60', then
40kg KB 2HS, 10x10, alternating with 80.5# DB PP 10x8, 45s rests
26 MAY: 40kg KB 2HS, 12x10, 1' ints, then
heavy bag work 2' rounds x7, 1' rests
27 MAY: 40kg KB 2HS, 12x10, 1' ints
