Kettlebell Lifting 2016
Re: Kettlebell Lifting 2015
24 Jun 16
Pull-Ups - 11,8,6,4,4
25 Jun 16
Jerks 2x26kg - 2 min @ 12 rpm, 2 min test, 2 min @ 12 rpm
Presses 2x24kg - 3 sets of 3 reps
Front Squats 2x24kg - 3 sets of 3 reps
I plan to add a third set to the jerks. I will use 26kg with the presses and squats next time.
27 Jun 16
Run - 10 min @ 8.3 mph (easy)
28 Jun 16
AM
Pull-Ups- 11,8,6,6,6
PM
Jerks 2x28kg - 2 min @ 10 rpm, 2 min rest, 2 min @ 10 rpm
Presses 2x26kg - 3
Front Squats 2x26kg - 3
AM
PM
Presses 2x26kg - 3
29 Jul 16
Pull-Ups - 11,9,6,4,4
30 Jun 16
Pull-Ups - 11,9,6,6,4
1 Jul 16
Pull-Ups - 11,9,6,6,6
30 Jun 16
1 Jul 16
3 Jul 16
2.5 mile run
5 Jul 16
Pull-Ups - 11
6 Jul 16
Pull-Ups - 12,8,6,4,2
2.5 mile run
5 Jul 16
Pull-Ups - 11
6 Jul 16
Digging the simple approach to all this. How's the body comp? Bells feeling decent?
7 Jul 16
Pull-Ups - 12,8,6,4,4
Thanks, Dunn! I am at about 15% body fat and weigh around 165. I will gradually cut back to 12% and 160 pounds. The bells are feeling lighter. My current goal is to set some 5 minute personal records with jerks and then work towards a 10 minute goal. I can do about 50% more reps in 10 minutes than I can do in 5 minutes. 60 jerks in 5 minutes makes 90 jerks possible.
8 Jul 16
Pull-Ups - 12,8,6,6,4
The new Marine Corps PFT standards are out:
12 Jul 16
Pull-Ups - 12,8,6,6,6
Run - 12 min @ 8.3mph
13 Jul 16
Jerks 2x26kg - 2 min @ 12 rpm, 2 min rest, 1 min @ 12 rpm
Front Squats 2x16kg - 5 sets of 5 (5 reps every 2 minutes)
I will try for 50 reps in 20 minutes with from squats. The goal is to add some muscle. I am starting really light and will add weight quickly. I don't want to get too sore.
Before bed:
Pull-Ups - 12,9,6,3,3
Before bed:
don't like front squat with kettlebels. i prefer squating with kbs on shoulders, that way hands are relaxing.
Thanks for the tip!
29 Jul 16
GTG Pull-ups - 60 total
Run - 16 min @ 8.3 mph
Presses 2x22kg - 5 every 2 minutes x 6
Supersetted with
Dumbbell curls - 5 every 2 minutes x 6
The run felt easier than the last few times. I will be at 20 minutes soon. I am starting a new grease the groove routine for pull-ups. Presses and curls were EDT style. I don't know what the Dumbbells weigh, but both exercises were with light weights.
30 Jul 16
Snatches - 30kg @ 12 rpm for 2 min, 2 min rest, 28kg @ 12 rpm for 2 min, 2 min rest, 26kg @ 12 rpm for 2 min
Snatches weren't a max effort. I just wanted to use the weights for each set. I will work towards 20 rpm.
Supersetted with
30 Jul 16
31 Jul 16
Jerks
28kg - 1 min @ 12 rpm
1 min rest
1 min rest
26kg - 1 min @ 12 rpm
1 min rest
24g - 1 min @ 12 rpm
KB Front Squats 2x16kg - 10 sets of 5 EDT Style
Jerks felt good. None of the sets were a max effort. I will add another set next time. I will use 20kg for the squats next time. I am starting light in the hope I don't get too sore for my runs.
Jerks
1 min rest
1 min rest
1 min rest
2 Aug 16
Run - 17 min @ 8.3mph
5 Aug 16
Run - 20 min @ 8.3mph
7 Aug 16
Jerks
1 min rest
1 min rest
1 min rest
24kg - 1 min @ 12 rpm
1 min rest
KB Front Squats 2x20kg - 3 sets of 5 reps
Dumbbell Curls - 3 sets of 5 reps
I averaged 60 pull-ups per day GTG style last week. I will increase it to 80 this week. I will start running at 8.4mph. I will work up to 20 minutes. I plan on doing my next PFT in January.
5 Aug 16
7 Aug 16
Jerks
1 min rest
1 min rest
1 min rest
1 min rest
9 Aug 16
GTG Pull-Ups - 80 total
Run - 10 min @ 8.4 mph
Pull-ups felt good. Last set still felt fresh. I will move to 100 a day next week if I still feel fresh at the end of the week. The run was deliberately easy. I will add time and add easy days when needed.
Re: Kettlebell Lifting 2016
12 Aug 16
Run - 12 min @ 8.4mph
GTG Pull-ups - 80
I will move to 100 pull-ups next week. The run felt good. My heart rate was 164 at the end. I will gradually increase the time.
GTG Pull-ups - 80
14 Aug 16
Jerks
1 min rest
1 min rest
1 min rest
I felt good at the end. I was tired, but I could have done sets with 24kg. I will keep adding sets and increasing weight over time.
Jerks
1 min rest
1 min rest
1 min rest
17 Aug 16
Run - 14 min @ 8.4mph
GTG Pull-ups - 100
GTG Pull-ups - 100
18 Aug 16
GTG Pull-ups - 100
19 Aug 16
Run - 16 min @ 8.4 mph
GTG Pull-ups - 100
Pull-ups feel good. I was doing sets of 4, but I will start doing sets of 5 next week. My heart rate at the end of the run was 172 bpm.
GTG Pull-ups - 100
19 Aug 16
GTG Pull-ups - 100
20 Aug 16
Jerks
2x28kg - 2 min @ 12 rpm
2 min rest
2x24kg - 1 min @ 12 rpm
1 min rest
2x20kg - 1 min @ 12 rpm
Front Squats 2x20kg - 5 sets of 5 reps (1 set every 2 minutes)
The first set of jerks was a good effort. The other sets were intentionally easy and I plan to do longer sets with them next time. I will move to 24kg for the front squats after doing 10 sets of 5 reps.
Jerks
2 min rest
1 min rest
21 Aug 16
Snatches
30kg - 2 min @ 16 rpm
2 min rest
28kg - 2 min @ 16 rpm
Snatches felt strong. I could have done a third set, but I stopped early. I will do 18 rpm next time. I will be using 32kg for my first set soon.
Snatches
2 min rest
22 Aug 16
GTG Pull-ups - 25
Felt weak today.
23 Aug 16
GTG Pull-ups - 50
Jerks 2x30kg - 3 min @ 6 rpm
Snatches - various weights for a few reps up to 32kg.
Pull-ups felt better, but the jerks felt heavy. I will add minutes as I get stronger. Cardio wasn't an issue.
24 Aug 16
GTG pull-ups - 75
Run - 30 min @ 6mph
Pull-ups felt much better today. The run was for recovery. My heart rate was only 136 at the end.
GTG Pull-ups - 25
Felt weak today.
23 Aug 16
GTG Pull-ups - 50
24 Aug 16
GTG pull-ups - 75
Run - 30 min @ 6mph
