Kettlebell Lifting 2016
DPR
Re: Kettlebell Lifting 2016
Post by DPR » Thu Aug 25, 2016 8:50 pm
25 Aug 16
GTG Pull-Ups - 75 total
I did 3 workouts today. Each workout was 5 sets of 5 reps. The reps are easy to avoid burnout and build volume.
DPR
Post by DPR » Sat Aug 27, 2016 6:06 pm
27 Aug 16
Jerks
2x28kg - 2 min @ 12 rpm
2 min rest
2x24kg - 1.5 min @ 12 rpm
1.5 min rest
2x20kg - 1.5 min @ 12 rpm
I made some progress since last week. I'll take it.
DPR
Post by DPR » Sun Aug 28, 2016 9:32 pm
28 Aug 16
Snatches 30kg -2 min @ 20 rpm, 2 min rest, 28kg - gassed out halfway through the set
Presses 2x24kg - 3 sets of 3 reps (easy)
Seated Dumbbell Curls - 8 reps
DPR
Post by DPR » Mon Aug 29, 2016 8:55 pm
29 Aug 16
Jerks 2x30kg - 3.5 min @ 6 rpm
All the reps felt good. I could have done more, but I will be patient.
DPR
Post by DPR » Tue Aug 30, 2016 9:14 pm
30 Aug 16
Snatches 32kg - 2 min @ 12 rpm
Gloved Snatches - 2 min @ 20 rpm
I am breaking in with 32kg. The weight felt heavier than expected, but this is the first time I have used 32kg in a long time.
DPR
Post by DPR » Wed Aug 31, 2016 9:30 pm
31 Aug 16
GTG Pull-ups - 50 total
Run - 10 min and 30 sec @ 8.5mph (1.5 miles)
The run felt good. I will build to 20 minutes and add speed. I plan to take my next PFT in January.
DPR
Post by DPR » Fri Sep 02, 2016 8:00 pm
2 Sep 16
AM
Snatches
30kg - 2 min @ 20 rpm
2 min rest
28kg - 1 min @ 20 rpm
PM
Jerks 2x28kg - 2 min @ 12 rpm
Snatches are better. I could have gone longer, but I will push a little farther next time.
DPR
Post by DPR » Sun Sep 04, 2016 4:31 pm
3 Sep 16
Easy 2.5 mile run.
DPR
Post by DPR » Mon Sep 05, 2016 10:05 pm
5 Sep 16
Snatches (left hand only) 32kg - 1.5 min @ 12 rpm
Gloved Snatches 20kg 2.5 min @ 20 rpm (1 min left/1.5 min right)
Seated Dumbbell Curls 35# - 12
1 Arm Row 32kg - 10
My right hand hot a hot spot from last Friday, so I didn't do ungloved snatches with it. 32kg snatches felt stronger than last time. Rows were easy.
DPR
Post by DPR » Tue Sep 06, 2016 9:13 pm
6 Sep 16
Jerks w/fix-o-meter 2x30kg - 3 min @ 6 rpm
My overhead lockout wasn't good, but I had beeps for each one except the last one. It'll get better as I find a good rest position. I used this in the past and found it useful.
DPR
Post by DPR » Tue Sep 13, 2016 9:34 pm
10 Sep 16
30 min morning run in New Orleans. Very humid.
13 Sep 16
Snatches 32kg - 2.75 min @ 12 rpm
Gloved Snatches 20kg - 2 min @ 20 rpm
Seated Dumbbell Curls 40# - 5/5
DPR
Post by DPR » Sun Sep 18, 2016 7:05 pm
15 Sep 16
Jerks 2x30kg - 2 min @ 6 rpm
The fix-o-meter stopped working and this messed up the workout. I will take 2 breaths at the top of each lockout next time.
18 Sep 16
Snatches 28kg - 3 min @ 16 rpm
Jerks 2x28kg - 3 min @ 8 rpm
Both sets were a sub max effort. I took 2 breaths during the lockout for each jerk. I also focused on bringing my elbows together during the drop so it is one smooth motion.
DPR
Post by DPR » Mon Sep 19, 2016 9:06 pm
19 Sep 16
Run - 12 min at 8.5mph
DPR
Post by DPR » Wed Sep 21, 2016 9:44 pm
20 Sep 16
Snatches
32kg - 1 min per arm
36kg - I just tried some 1 rep sets.
I used to do snatches with 40kg, but that was a long time ago.
21 Sep 16
Jerks 2x30kg - 4 min @ 6 rpm
Jerks felt strong. Don't push it too fast. I took 2 breaths during the lockout and the video I took looked good. I need to work on dropping it more efficiently.
DPR
Post by DPR » Thu Sep 22, 2016 9:58 pm
22 Sep 16
GTG Pull-ups - 50
1 arm kb press - 16kgx3, 20kgx3, 24kgx3, 28kgx3
Run - 40 min @ 6mph (HR stayed under 140 BPM)
DPR
Post by DPR » Sat Sep 24, 2016 6:44 pm
24 Sep 16
Snatches 28kg - 3.75 min @ 16 rpm
I stopped the set 15 seconds early because I could feel some skin tearing. It is just a small spot on my right palm. I was probably not dropping it correctly. Cardio felt good.
DPR
Post by DPR » Sun Sep 25, 2016 10:40 pm
25 Sep 16
Jerks 2x28kg - 4 min @ 8 rpm
Seated alternate dumbbell curls 40# - 7/7
1 arm row 36kg - 10/10
Windmill 16kg - 5/5
Jerks felt strong. I will gradually add time.
DPR
Post by DPR » Tue Sep 27, 2016 10:21 pm
26 Sep 16
GTG pull-ups - 25
1 arm kb press - 16kg 3/3, 20kg 3/3, 24kg 3/3, 30kg 3/3
Increase reps for last set next time. Medium effort.
27 Sep 16
GTG pull-ups - 50
Run - 13 min @ 8.5 mph
Keep adding time to the run. Medium effort.
