Alfred's self hating log of pointlessness
- Alfred_E._Neuman
- Sgt. Major
Re: Alfred's self hating log of pointlessness
Fri 5/05/17
Rode the bike to work.
After work at the gym:
Juggernaut Method, 10s Wave Intensification Phase
Warm-up with shoulder mobility and light band face pulls.
Press: work up to 65 x 5, 75 x 5, 80 x 10, 10, 15, rest 2:30 between the sets of 10.
Face pulls between sets of press
Pull-ups: BW+35# x 5 x 5 sets, full recovery between sets.
Dips: BW+35# x 6, 6, 7, 7, 7 on bars
alternated with
DB rows: 60 x 12 l/r x 5 sets
Rest as needed between sets
Messed around with L-sits, HLR, and handstands for 10 minutes.
Going to take a minute to find the groove on bar dips. I've only done them on rings for years. Handstand is getting a little better. Press was much stronger today than last week. Been eating more, so that may be helping.
alternated with
- Alfred_E._Neuman
- Sgt. Major
Sat 5/06/17
Rode the bike to the coffee shop and then to the gym before lunch.
Warm-up with rope skipping, hip mobility.
DL: Work up to 150 x 5, 170 x 5, 185 x 10, 10, 20, rest 2:30 between the sets of 10
Box jumps x 3 to medium box, 3 x 2 sets to high box between warm-up sets of DL
Squat: Warm-up to 160 x 10 x 4 sets, rest 2:00 between sets. Squats felt good.
Hang PS: Warm-up, 40kg x 3 x 2 sets, 43kg x 3, 45kg x 3 x 2 sets
Sled push: 6 trips down and back with 2 plates on the sled, 1:30 rest between pushes.
Some abs for a couple sets.
Good day. The wife is at yoga teacher training this weekend, so I slept in and went to the coffee shop for bit. Then headed over to the gym and got in a really good workout. Too few days like this in my life right now. Too much work and stress and too little relaxing time to do the things I enjoy.
- Alfred_E._Neuman
- Sgt. Major
Sun 5/07/17
Easy 5k row in the afternoon.
Stretch/mobility and foam roll in the evening.
- Alfred_E._Neuman
- Sgt. Major
Mon 5/08/17
At home after work:
Juggernaut Method, 10s Wave Realization Phase
Bench: 95 x 5, 115 x 3, 130 x 1, 140 x 16, 5, 5, 5 Rest 2:30 between sets.
Bent over rows: 160 x 8 x 5 sets, rest 2:00 between sets
Dips: 15, 15, 15, 15, 15
alternated with
Pull-ups: 12, 11, 10, 9, 9
Rest 1:30-2:00 between sets
Ab wheel x some for a few
Got 16 solid reps on my AMAP set. Did a few easy sets of 5 at the same weight for volume.
Using the formula for moving up my working max, I'll plug in 200 for the 8's wave of bench. 15# improvement over the 185 working max for the 10's wave.
At home after work:
alternated with
- Alfred_E._Neuman
- Sgt. Major
Tues 5/09/17
Stretch and roll in the evening.
Dropped a 22" GL wheel on my left fingers this afternoon. Got them caught between the inside top of the wheel and the brake disk. Didn't break any, but pinched the ring and pinky finger HARD and cut both. My ring finger has a pretty deep gash. Not good.
- Alfred_E._Neuman
- Sgt. Major
Wed 5/10/17
At the gym after work:
Warm-up with hip mobility
Squat: work up to 115 x 5, 135 x 3, 160 x 1, 170 x 20, Rest as needed. Some good huffing and puffing after 15 reps.
170 x 5 x 3 sets for back off, rest 2:30 between sets.
FS: 135 x 5, 6, 6, 6, Rest 2:30 between sets.
Barbell walking lunge: 95, 95, 105 x 10 steps l/r, Rest 2:00 between sets
GHD sit-ups and back raises x 10 x 3 sets each.
Had to go and get my left ring finger stitched up this morning, and get a tetanus shot. Joy. Couldn't do cleans and had to set up squat stands to rack my lunges. Ordered some DL straps from Elite so I can hopefully pull Saturday morning.
According to my Juggy spreadsheet, my working max for the 8's wave of squats should be 250 pounds. That seems pretty ambitious, so I'm only moving up to 240. Looking at the numbers for next month and the weights based on 240# are a lot more in range with what I think I can handle right now. Slow and steady.
- Alfred_E._Neuman
- Sgt. Major
Thurs 5/11/17
Walked ~45 minutes before supper.
Roll and stretch in the evening.
- Alfred_E._Neuman
- Sgt. Major
Fri 5/12/17
At home after work:
Warm-up with shoulder mobility.
Press: Work up to 60 x 5, 70 x 3, 85 x 1, 90 x 14, 5, 5, 5, 2:30 rest between sets.
Bent over row: 135 x 12, 155 x 12, 165 x 9, 9, 9, 9, rest 2-2:30 between sets
Bench: 135 x 10 x 4 sets, 1:30 rest between sets
Pull-ups: 10 x 3 sets
Better than I had hoped on the pressing. Will move up to 125 for the 8s wave working max.
Rows and pull-ups were done using straps since I can't grip with my left hand worth a shit right now. The way my stitches are, I also couldn't do push-ups like I had wanted since I can't straighten my finger all the way either. Also no dips. So bench it was since so I could rest the bar at the base of my palm.
At home after work:
- Alfred_E._Neuman
- Sgt. Major
Sat 5/13/17
At the gym before lunch:
Box jumps x 3 x 4 sets to high box
DL: work up to 135 x 5, 165 x 3, 190 x 1, 205 x 20, 5, 5, 5
Used straps due to stitches in my left hand.
Squat: work up to 65 x 10 x 4 sets, 2:00 rest
Sled+90# x 7 trips up/down the floor, 1:30 rest between sets
ABS
Good workout. Couldn't do my snatches due to not being able to grip the bar. Sucks. But at least I could DL with straps. DL felt solid. Paused all reps on the floor for a full reset. Helps to teach me to get tight.
Squat was easier than last week.
Sled kicked my ass.
ABS
Sled kicked my ass.
- Alfred_E._Neuman
- Sgt. Major
Sun 5/14/17
Row 6k, 30 minutes of easy yoga before supper.
- Alfred_E._Neuman
- Sgt. Major
Mon 5/15/17
At home after work:
Juggernaut Method, 10s Wave Deload
Bench: 75 x 5, 95 x 5, 115 x 5, 135 x 3, 165 x 1, 185 x 1
Worked up to easy single at current Working Max
Row: 135 x 6
Pull-ups/Chin-ups: 5 x 5 sets, alternating grips each set
Push-ups on rings x 15 x 5 sets, feet on a bench
Ab wheel x a few
Used a combo of the original 5/3/1 deload and the 7th Week Deload from the new book. Worked well. And it's nice to know that the Working Max is pretty spot on since the single at WM was damned easy.
At home after work:
Row: 135 x 6
Ab wheel x a few
- Alfred_E._Neuman
- Sgt. Major
Tues 5/16/17
At home after work:
Row 5:00 warm-up
20:00 of stretching and mobility.
Walked around the block with the wife.
At home after work:
Row 5:00 warm-up
- Alfred_E._Neuman
- Sgt. Major
Wed 5/17/17
Box jumps x 3 x 3 sets done during squat warm-up
Squat: 95 x 5, 115 x 5, 135 x 5, 175 x 3, 200 x 1, 225 x 1
Worked up to a single at my Working Max for the 10's wave.
FS: 155 x 3 x 3 sets
Barbell walking lunge: 115 x 5 steps l/r x 3 sets. Rest 2:00 between sets
Worked 6 sets of 5 easy pull-ups/chin-ups in with squat sets. First day I could comfortably grip the bar after cutting my finger.
GHD back raises and HLR x 3 sets each.
Another good day. Legs had plenty of strength for the single at my working max. Weak link is my midsection. Need to work on this, or maybe just get better at getting tight under the bar. Still could have gotten at least a triple at the weight without killing myself, so I'm feeling good about the working max I used for this wave. My goal for the end of the program is a solid 10+ reps at 225.
Everything else felt very easy.
I'm ready to get these damned stitches out of my finger so I can grab a bar. Right now I have to hold my finger slightly off the bar so it doesn't pull on the stitches.
- Alfred_E._Neuman
- Sgt. Major
Thurs 5/18/17
Easy 3k row and stretching after work .
- Alfred_E._Neuman
- Sgt. Major
Fri 5/19/17
At home after work:
Press: 50 x 5, 60 x 5, 70 x 5, 95 x 3, 105 x 1, 115 x 1.
Worked up to my training max for the 10s wave. Very easy.
Pull-ups/chin-ups: 5 x 8 sets done during pressing. Alternated grip each set.
Ring rows and push-ups: 10/20 x 4 sets
Rest 1:00 between exercises
Ab wheel x a few sets from knees.
At home after work:
- Alfred_E._Neuman
- Sgt. Major
Sat 5/20/17
Slept late after being out late last night going to a Yacht Rock show. Drank a *bit* too much.
Rode the bike to the coffee shop and then over to the gym before lunch.
DL: 135 x 5 x 2 sets, 165 x 5, 225 x 3, 255 x 1, 275 x 1 Very easy.
Worked up to a single at WM for this wave.
Squat: worked up to 175 x 5 x 5 sets, 1:00 rest between sets.
Super smooth on the squats. The best they've felt so far.
Back raises on GHD: 10 x 4 sets
Pushed the sled with 2 plates x 8 trips up/down the floor for conditioning. 1:30 rest between pushes.
Was able to grip the bar double overhand without straps for the first time since cutting my hand. I'll take the stitches out tomorrow or Monday.
- Alfred_E._Neuman
- Sgt. Major
Sun 5/21/17
Easy 6k row in the afternoon.
- Alfred_E._Neuman
- Sgt. Major
Mon 5/22/17
At home after work:
Juggernaut Method, 8s Wave Accumulation Phase
Bench: Work up to 130 x 8, 8, 8, 8, 20!!, Rest 2:00-2:30 between sets.
Band pull aparts for a few between sets of bench.
1-arm row: 28kg x 12 l/r x 3 sets. Rest 1:30-2:00 between sets
Pull-ups: 8, 8, 8, 7, 7, 6, rest 1:30 between sets
Dips: 10 x 4 sets, rest 1:30 between sets
HLR alternated with push-ups x 3 sets. Bunch o' rest.
At home after work:
- Alfred_E._Neuman
- Sgt. Major
Tues 5/23/17
Row 2k easy warm-up. Mobility and roll for 30 minutes.
- Alfred_E._Neuman
- Sgt. Major
Wed 5/24/17
Warm-up with hip mobility. Broad jumps x 3 x 3 done with squat warm-up sets.
Squat: work up to 160 x 8, 8, 8, 8, 20, Rest ~2:00 between sets
FS: 155 x 4 x 3 sets, rest 2:00
Walking lunge: 105 x 10 steps l/r x 3 sets
6 rounds of:
1-arm Swing 24kg x 10
Pull-ups x 5
Nice squat workout. Last set actually felt the best. Probably mental due to looking well past 8 reps on the last set. Was pretty spent for the FS and the lunges. Just getting work in. Still not sure about cleans with a bar until the skin on my finger gets a little thicker. It's still pretty thin where it's healing from my cut.
I'm thinking it's probably best to just use swings or RDLs instead of cleans for the rest of this cycle. Maybe pick a 5/3/1 cycle that's heavy on cleans after the Juggy method is done if I still want to work on those. Just focus on getting that 225 x 10 squat goal for this cycle. No real goals for pressing. I much prefer BW for upper body, so the bar is just a way to overload those movement.
6 rounds of:
Pull-ups x 5
- Alfred_E._Neuman
- Sgt. Major
Thurs 5/25/17
Walked for 40 minutes around the neighborhood with the wife before supper. Pretty tired and stressed as hell from work. Easy recovery tonight.
- Alfred_E._Neuman
- Sgt. Major
Fri 5/26/17
At home after work:
Warm-up with shoulder mobility, plyo push-ups x 3 x 2 sets.
Press: work up to 85 x 8, 8, 8, 8, 14, rest 2:00-2:30 between sets.
Pull-ups: BW+16kg x 5 x 6 sets, rest as needed between sets.
Push-ups with 45# plate: 8 x 4 sets
alternated with
Ring rows with feet on bench x 12 x 4 sets
L-sit and ab wheel for x some x a few for abs.
At home after work:
alternated with
- Alfred_E._Neuman
- Sgt. Major
Sat 5/27/17
Rode the bike to the coffee shop and then to the gym.
Warm-up with hip mobility, box jumps x 4 x 3 sets.
DL: work up to 195 x 8, 8, 8, 8, 20, 2:00-2:30 rest between sets
Squat: work up to 185 x 6 x 5 sets, 2:00 rest between sets
Pushed sled+2 plates x 7 trips up/down the floor. Rest 1:00-1:30 between sets. These wiped me out today.
Messed around with L hang pull-ups for a few sets of 3 for fun.
Was tired today. Sleep has been shit lately. Stressed at work and just over it. Weights felt good. DL is too light. the squats felt solid as hell. Focused on good bar speed out of the hole. Used my belt just to try and get used to it. Finally found the right tension and it actually seemed to help this time. I think I've been using it too tight when I tried it before.
After pushing the sled I didn't feel like doing jack shit else. So no back raises or swings today.
- Alfred_E._Neuman
- Sgt. Major
Sun 5/28/17
Row 6k before supper.
Went for a walk on the Beltline in the evening.
- Alfred_E._Neuman
- Sgt. Major
Mon 5/29/17
Juggernaut Method, 8s Wave Intensification Phase
Warm-up with shoulder mobility, rope skipping.
Med ball chest toss x 4 x 3 sets
Bench: work up to 120 x 3, 135 x 3, 145 x 8, 8, 18, rest 2:30 between sets
Light band pull-aparts between sets
Row: 155 x 12, 165 x 8, 8, 175 x 6, 6
Dips: 15, 12, 10, 10, 8
alternated with
Pull-ups on rings: 8, 8, 8, 7, 6, 6, 6, 6, 6 = 55 reps
HLR practice x 5 sets. Still a work in progress.
alternated with
