Just keep showing up!
Re: Training the basics, an exercise in efficiency.
Friday 20.11.15
Vol Phase 1, W3 D3
1a. Squats:
bar x 2 x 10
60kg x 8
90kg x 5
110kg x 5 x [1, 2, 3}
s/s
1b. Pull Ups: 7 x 5
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
82.5kg x 5 x [1, 2, 3]
s/s
2b. Pull Ups: 6 x 5
55 minutes.
Vol Phase 1, W3 D3
1a. Squats:
bar x 2 x 10
60kg x 8
90kg x 5
s/s
1b. Pull Ups: 7 x 5
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
s/s
2b. Pull Ups: 6 x 5
55 minutes.
I'd say on the bottom of that self-actualisation pyramid shit, proper decent coffee is in there with wifi, tits, food and shelter
Mon 23.11.15
6am - 3.9 miles, 67 minutes, with baby in front sling
7pm - Intensity phase 1, w1, d1
Squat:
bar x 2 x 10
60kg x 8
90kg x 5
110kg x 3
122.5kg x 5 x 3
Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
87.5kg x 3, 3, 3, 3, 6
- felt good so repped the final set
Pull ups:
bw x 3 x 3
+6kg x 3
+8kg x 3
+10kg x 3
+12kg x 3
bw x 5
db lateral raises:
17.5kg x 5
15kg x 8
12.5kg x 10
Squat:
bar x 2 x 10
60kg x 8
90kg x 5
110kg x 3
122.5kg x 5 x 3
Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
Pull ups:
bw x 3 x 3
+6kg x 3
+8kg x 3
+10kg x 3
+12kg x 3
bw x 5
db lateral raises:
17.5kg x 5
15kg x 8
12.5kg x 10
Wednesday 25.11.15
6am: 3.35 miles, 51 mins, baby in front sling
5pm: intensity phase 1, w1, d2
1. Deadlift:
bar x 2 x 10
70kg x 2 x 8
110kg x 5
130kg x 3
150kg x 5 x 3
2a. Chest supported bb row:
Bar x 10
50kg x 10
65kg x 3 x 10
2b. SA Db ohp:
15kg x 10/10
20kg x 4 x 10/10
1. Deadlift:
bar x 2 x 10
70kg x 2 x 8
110kg x 5
130kg x 3
150kg x 5 x 3
Bar x 10
50kg x 10
65kg x 3 x 10
2b. SA Db ohp:
15kg x 10/10
20kg x 4 x 10/10
Thurs 26.11.15
6am: 4.8 miles, 87 minutes, wet and slippy under foot. Baby in front sling.
Friday 27.11.15
6am - 4 miles, 67 minutes, baby in front sling
11.45am - Intensity phase 1, w1, d3
1a. Squat:
bar x 2 x 10
60kg x 8
90kg x 5
110kg x 3
125kg x 5 x 3
s/s
1b. pull-ups:
Bw x 3 x 3
+8kg x 6 x 2
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
90kg x 5 x 3
2b. Pull-ups
+8kg x 6 x 2, then 1 x 4
1a. Squat:
bar x 2 x 10
60kg x 8
90kg x 5
110kg x 3
125kg x 5 x 3
s/s
1b. pull-ups:
Bw x 3 x 3
+8kg x 6 x 2
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
90kg x 5 x 3
2b. Pull-ups
Sat 28.11.15 - baby in hospital. stress. Bronchiolitos, nothing more serious.
Monday 30.11.15
1.15pm - Intensity phase 1, w2, d1
1a. Squat:
bar x 2 x 10
60kg x 8
90kg x 5
110kg x 3
127.5kg x 5 x 3
s/s
1b. pull-ups:
Bw x 2 x 3
+6kg x 6 x 3
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
92.5kg x 5 x 3
2b. Pull-ups
+6kg x 7 x 3
Monday 30.11.15
1a. Squat:
bar x 2 x 10
60kg x 8
90kg x 5
110kg x 3
127.5kg x 5 x 3
s/s
1b. pull-ups:
Bw x 2 x 3
+6kg x 6 x 3
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
92.5kg x 5 x 3
2b. Pull-ups
+6kg x 7 x 3
Wednesday 02.12.15
5.30am: 5 miles, 86 mins, baby in front sling
5pm: intensity phase 1, w2, d2
1. Deadlift:
60kg x 10
110kg x 8
140kg x 5
155kg x 5 x 3
Bar x 10
50kg x 10
65kg x 4 x 10
2b. SA Db ohp:
12.5kg x 10/10
17.5kg x 10/10
22.5kg x 8/8, 7/7, 6/6, 5/5
1. Deadlift:
60kg x 10
110kg x 8
140kg x 5
155kg x 5 x 3
Bar x 10
50kg x 10
65kg x 4 x 10
2b. SA Db ohp:
12.5kg x 10/10
17.5kg x 10/10
Thursday 03.12.15
1.30pm - 3 miles in 27:30
Friday 04.12.15
1.15pm - intensity phase 1, w2, d3
1a. Squat:
bar x 2 x 10
60kg x 8
100kg x 5
120kg x 3
130kg x 5 x 3
1b. Pull ups:
bw x 2 x 3
+10kg x 6 x 2
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
95kg x 5 x 3
2b. Pull ups:
+10kg x 7 x 2
Dropset on final double --> bw x 5
Friday 04.12.15
1a. Squat:
bar x 2 x 10
60kg x 8
100kg x 5
120kg x 3
130kg x 5 x 3
1b. Pull ups:
bw x 2 x 3
+10kg x 6 x 2
2a. Bench:
bar x 2 x 10
50kg x 8
65kg x 5
80kg x 3
95kg x 5 x 3
2b. Pull ups:
+10kg x 7 x 2
Sat 05.12.15
Played rugby.
Mon 07.12.15
Took a rest day.
Tues 08.12.15
3 miles, 27:30.
Wed 09.12.15
Lunch - 3 miles, 31:30 mins
Gym - intensity phase 1, w3, d2
Deadlift:
40kg x 10 (as that is how I found the bar)
70kg x 8
110kg x 5
140kg x 3
160kg x 5 x 3
Inverted rows: bw x 10, +10kg x 4 x 10
s/s
SA DB OHP: 12.5kg x 10/10, 17.5kg x 4 x 10/10
Got bw back over 13 1/2 stone for the first time since May.
Played rugby.
Mon 07.12.15
Took a rest day.
Tues 08.12.15
3 miles, 27:30.
Wed 09.12.15
Deadlift:
70kg x 8
110kg x 5
140kg x 3
160kg x 5 x 3
s/s
Thurs 10.12.15
2.75 miles; 27 ish minutes
Fri 11.12.15
Intensity phase 1, w3, d3
1. Pull ups: 6 x 5
2a. Bench:
bar x 2 x 10
50kg x 8
70kg x 5
85kg x 3
100kg x 2
95kg x 5 x 3
2b. Pull ups: 7 x 3
3. Squats:
60kg x 10
80kg x 8
100kg x 3
120kg x 3
130kg x 5 x 3
Bench was ok, skipped over 97.5 which i should have done on Monday and went straight to 100. Knew first set it wasn't possible to do all the prescribed reps so dropped back to 95.
Conversely, squats felt easy and awesome.
Sat 12.12.15
6am: 6 mile stroll in 1hr 46 with baby in front sling. Not fast but portions off road in the dark.
Fri 11.12.15
1. Pull ups: 6 x 5
2a. Bench:
bar x 2 x 10
50kg x 8
70kg x 5
85kg x 3
100kg x 2
95kg x 5 x 3
2b. Pull ups: 7 x 3
3. Squats:
60kg x 10
80kg x 8
100kg x 3
120kg x 3
130kg x 5 x 3
Sat 12.12.15
Monday 14.12.15 -MMS Day 1
Bench:
Bar x 3 x 10
50kg x 5
70kg x 5
80kg x 5
85kg x 5
90kg x 5 (comfortable)
95kg x 5 (5th rep, rpe 9)
95kg x 5 (4th rep hard, 5th rep rpe 10)
- supposed to work up to a top set of a comfortable 5 reps to base future training from. Will be sensible and use 90kg.
Db batwings:
10kg x 2 x 10s
12.5kg x 2 x 10s
15kg x 2 x 10s
17.5kg x 2 x 10s
SA DB ohp:
10kg x 5/5
15kg x 5/5
20kg x 5/5
25kg x 4/4 - hard
Bird dogs: 3 sets of 3 each side. Each set slightly narrower.
Complex:
Row-clean-front squat-military press-back squat-good morning
3 reps per movement - 20kg/40kg/50kg
High rep squats: 42.5kg x 30
Bench:
Bar x 3 x 10
50kg x 5
70kg x 5
80kg x 5
85kg x 5
Db batwings:
10kg x 2 x 10s
12.5kg x 2 x 10s
15kg x 2 x 10s
17.5kg x 2 x 10s
SA DB ohp:
10kg x 5/5
15kg x 5/5
20kg x 5/5
25kg x 4/4 - hard
Complex:
Wed 16.12.15 -MMS Day 2
Bench:
Bar x 2 x 10
50kg x 10
90kg x 2 x 2-3-5
- bit rushed, used the right weight though. would have been silly to have used 95
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 2 x 2-3-5
- second set at top weight actually felt better and more explosive
Complex: 5x thru, 3 reps per movement - 15kg/35kg/50kg/50kg/50kg
High rep squats: 42.5kg x 2 x 30
Bench:
Bar x 2 x 10
50kg x 10
90kg x 2 x 2-3-5
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 2 x 2-3-5
Friday 18.12.15 -MMS day 3
Bench:
Bar x 2 x 10
50kg x 10
74kg x 5
90kg x 3 x 2-3-5
- 3rd set no harder than second, good stuff.
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 3 x 2-3-5
- same comment as bench
Complex: 2x thru, 5 reps per movement -50kg/50kg
- much harder, 50kg mil press after the Db work was right on the limit. May need to reduce weight when reps go up
High rep squats: 42.5kg x 30, 52.5kg x 30
- had to work noticeably harder second set, paused for some deep breaths at 20 reps.
Bench:
Bar x 2 x 10
50kg x 10
74kg x 5
90kg x 3 x 2-3-5
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 3 x 2-3-5
Bench:
Bar x 2 x 10
50kg x 10
74kg x 5
90kg x 3 x 2-3-5
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 3 x 2-3-5
Bar x 2 x 10
50kg x 10
74kg x 5
90kg x 3 x 2-3-5
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 3 x 2-3-5
Tues 22.12.15
Bench:
Bar x 2 x 10
50kg x 10
74kg x 5
90kg x 3 x 2-3-5
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 3 x 2-3-5
Bench:
Bar x 2 x 10
50kg x 10
74kg x 5
90kg x 3 x 2-3-5
Db batwings:
17.5kg x 10 x 5s
SA DB ohp:
12.5kg x 10/10
17.5kg x 5/5
22.55kg x 3 x 2-3-5
Tuesday 22.12.15
Bench:
Bar x 3 x 10
50kg x 10
70kg x 5
85kg x 3
95kg x 2 x 2-3-5
90kg x 9
- 95 was nice and easy, especially when compared to when I tried it 2 weeks ago. 90x9 was all good too, 10 was probably there but I had no spotter and played safe
Db batwings:
17.5kg x 5 x 10s
SA DB ohp:
15kg x 5/5
20kg x 3/3
25kg x 2/2, 3/3, 5/5 (hard), 2/2, 3/3 (hard), 5/4 + 1 (horrible form)
Bird dogs: 2 sets of 2 each side. experimented with 3 count box breathing for the first time
Complex: 3x thru, 5 reps per movement - 45kg
- better, glad I dropped the weight.
High rep squats: 52.5kg x 3 x 25
- not hard work, yet
Bench:
Bar x 3 x 10
50kg x 10
70kg x 5
85kg x 3
95kg x 2 x 2-3-5
90kg x 9
Db batwings:
17.5kg x 5 x 10s
SA DB ohp:
15kg x 5/5
20kg x 3/3
Sun 27.12.15
Trained with my brother in law, Merlin
Bench:
Bar x 2 x 10
50kg x 10
80kg x 5
95kg x 3 x 2-3-5
- extra rung at 95, left solid if not explosive, was able to just keep working through
Db batwings:
22.5kg x 5 x 5s
- upped the weight, a lot, for the new shorter holds, this was tricky
SA DB ohp:
15kg x 8/8
20kg x 3/3
25kg x 3 x 2-3-5
- much, MUCH better than the last session and an extra rung of lifts; however, none of these lifts were easy, in fact they were really hard but I didn't get my normal drop off and was able to keep grinding through them
Bird dogs: 3 sets of 2 each side. each set with a more narrow base
- same as last time, breezed through.
High rep squats: 42.5kg x 30, 52.5kg x 30, 62.5kg x 30
- WOW, significantly harder work, legs were fried for the rest of the day after this.
Bench:
Bar x 2 x 10
50kg x 10
80kg x 5
95kg x 3 x 2-3-5
Db batwings:
22.5kg x 5 x 5s
SA DB ohp:
15kg x 8/8
20kg x 3/3
25kg x 3 x 2-3-5
Tues 29.12.15
8am - Dan John mobility workout
Circuit of:
5 pull ups (my addition, not part of the DJ plan)
25 kb swings
1 goblet squat
10 march in place
mobility exercise*
*TRX deep squat stretch
TRX long stretch left
TRX long stretch right
TRX stoney stretch left knee down
TRX stoney stretch right knee down
Windmill stick look left
Windmill stick look right
Hip flexor stretch left knee down
Hip flexor stretch right knee down
ran out of time before work so didn't do the pull ups etc before either HF stretch or the final round after the mobility work
Circuit of:
25 kb swings
1 goblet squat
10 march in place
mobility exercise*
Wednesday 30.12.15
Bench:
Bar x 2 x 10
50kg x 10
80kg x 5
95kg x 2-3-5-7, 2-3-5, 2-3-5
- extra set within the first ladder
Batwings:
22.5kg x 5 x 5s
- much better
SA DB OHP:
12.5kg x 8/8
17.5kg x 3/3
22.5kg x 3 x 2-3-5
- dropped the weight, much better, crisp reps
Complex: 5x thru, 5 reps per movement - 45kg
- this was WORK
High rep squats:
42.5kg x 10,
52.5kg x 30,
62.5kg x 40 + 10 = 50 total reps
Paused for deep breaths at 25 and 36 reps, but bar stayed on my back
Bench:
Bar x 2 x 10
50kg x 10
80kg x 5
Batwings:
22.5kg x 5 x 5s
- much better
SA DB OHP:
12.5kg x 8/8
17.5kg x 3/3
22.5kg x 3 x 2-3-5
- this was WORK
High rep squats:
42.5kg x 10,
52.5kg x 30,
Sat 02.01.16
1. Squats:
High bar
Bar x 2 x 10
60kg x 10
80kg x 10
100kg x 10
Belt on...
120kg x 10
Normal bar position
130kg x 1
140kg x 1
150kg x 1
160kg x 1
170kg x 1
Beltless, paused for 3 count
120kg x 3 x 3
2a. WG LPD:
50kg x 15
80kg 3 x 12 (with straps)
2b. Stick assisted ghetto ghr:
4 x 8
3a. Kneeling Ab wheel roll out:
3 x 10
3b.bb curl:
30kg x 15/15/10
Squats were immense, a combination of caloric surplus, improved leverages and a sustained period of sub maximal rep work before Xmas.
Also, walked about 9 miles today.
Diet: on point.
1. Squats:
High bar
Bar x 2 x 10
60kg x 10
80kg x 10
100kg x 10
Belt on...
120kg x 10
Normal bar position
130kg x 1
140kg x 1
150kg x 1
160kg x 1
170kg x 1
120kg x 3 x 3
2a. WG LPD:
50kg x 15
4 x 8
3 x 10
3b.bb curl:
30kg x 15/15/10
Diet: on point.
03.01.16
Out along the cliffs and back through Sheringham Park. 5 miles, 8O minutes with G in sling.
04.01.16
Out to E Runton and back along the cliffs/beach. 5.75, 93 minutes, G in sling.
Gym time:
1. Bench
Bar x 2 x 10
50kg x 10
80kg x 5
95kg x 3
105kg x 3
110kg x 1
115kg x 1
120kg x close, but spotter did need to offer some fingertip assistance
100kg x 5
80kg x 12
2a. Inverted rows: bw x 6 x 12
2b. Pallof press: '40' x 4 x 10/10
3a. Db lateral raise: 10kg x 3 x 15
3b. Cable tricep pushdowns: '50' x 3 x 15 (easy)
3c. Cable Facepulls w/ext rot: '35' x 3 x 15
04.01.16
Gym time:
1. Bench
Bar x 2 x 10
50kg x 10
80kg x 5
95kg x 3
105kg x 3
110kg x 1
115kg x 1
100kg x 5
80kg x 12
06.01.16
1pm - lunch break
Walked 2.5 miles in 40 mins, wearing 40lb weight vest.
Stopped at kids play park and did some monkey swings (10 rungs) and 1 pull up wearing the vest.
Next, without the vest, wide neutral grip, pull ups x 9/7/6
5pm
1. Deadlifts:
70kg x 8, 6
110kg x 5
130kg x 3
150kg x 1
170kg x 1
Belt on...
180kg x 1
2. Squats:
60kg x 10
100kg x 4 x 10
3a. Leg raises: 4 x 8
3b. Pull aparts: 4 x 25
1pm - lunch break
5pm
1. Deadlifts:
70kg x 8, 6
110kg x 5
130kg x 3
150kg x 1
170kg x 1
Belt on...
180kg x 1
2. Squats:
60kg x 10
100kg x 4 x 10
1a. OHP:
Bar x 10
30kg x 5
40kg x 3
50kg x 1
60kg x 1
70kg x 1
75kg x 1
80kg x f
55kg x 8, 7, 6.
1b. Pullaparts: 10 x 15
2a. Low inc Db bench: 17.5kg x 5 x 15
2b. Inverted rows: bw x 15/15/12/10/10
3a. Lying deadstop tricep extns: 8kg x 15, 10kg x 2 x 15
3b. Kneeling roll outs: 3 x 10
Bar x 10
30kg x 5
40kg x 3
50kg x 1
60kg x 1
70kg x 1
75kg x 1
80kg x f
55kg x 8, 7, 6.
Sat 09.01.16
played 80 minutes of rugby
Mon 11.01.16 - Nuckols Simple Progression (NSP) W1 D1
1a. Squats:
bar x 10
60kg x 10
90kg x 8
112.5kg x 5 x 8
1b. 3pt deadstop db rows: 17.5kg x 8 x 10/10
- even with that volume, weight was too easy
2a. RDL: 90kg x 4 x 10
2b. Shrug: 90kg x 4 x 10
3a. steep decline bench sit ups: 3 x 12
3b. Xbody db curls@ 17.5kg x 3 x 10/10
1a. Squats:
bar x 10
60kg x 10
90kg x 8
112.5kg x 5 x 8
Tues 12.01.16
5.30am, 5 miles, 82 minutes, with G (aged 11weeks) in sling.
1pm, 2 miles wearing 40lb weight vest, 34 minutes.
10 rung monkey bar swings wearing vest,
Wide neutral grip pull ups: bw x 10, 8, 7.
