The Big Lick Strength Emporium
grip junky
Location: Sitting on the can, eating a pork chop, reading the koran.
Re: The Big Lick Strength Emporium
Post by grip junky » Thu Feb 16, 2012 5:46 pm
2/15/12
cb wu
barbell highbar squat
147lbs 1set 3reps 237lbs 1set 3reps 274 1/2lbs 3sets 3reps
kb over head carry
70,53lbs 2trips 53,70lbs 2trips 88lbs 2trips
kb two hand swing
115lbs 5sets 5reps
db one hand bench
70lbs 3sets 8reps
grip junky
Post by grip junky » Mon Feb 20, 2012 5:40 pm
2/16/12
cb wu
kb hang clean
53lbs 3sets 10reps
med ball throws 30lbs=83 throws 20lbs=24throws
2/18/12
fooled around with a club bell
then did farmers around the block. I did 117 a hand and it took me around 31 minutes, Sarah the crossfit girl did, 32 a hand and took about 16 minutes
2/19/12
cb wu
med ball throws, 30lbs=108throws 20lbs=24throws
footwork
grip junky
Post by grip junky » Wed Feb 22, 2012 5:52 pm
2/20/12
cb wu
kb over head carry
88lbs 3 trips
stone squats
5sets 3reps
barbell highpull
135lbs 5sets 5reps
ring push ups
bw 2sets 8reps bw 2sets 6reps bw 1set 4reps
ghr
bw 7sets 5reps
2/21/12
cb wu
threw med balls 30lbs- 136throws 20lbs 15throws
sand bag winds 20lbs 3sets 3reps
grip junky
Post by grip junky » Fri Feb 24, 2012 5:35 pm
2/23/12
cb wu
kb clean and press
70,53lbs 1set 3reps 88lbs 1set 2reps 53,70lbs 1set 3reps 88lbs 1set 2reps
same
same
same
sandbag carry
170lbs 3trips
kb front squats
53,70lbs 2sets 3reps 70,53lbs 2sets 3reps
kb swing two hand
88lbs 3sets 5reps
grip junky
Post by grip junky » Mon Feb 27, 2012 5:47 pm
2/25/12
med ball throws 30lbs-146, 12lbs-21
2/26/12
cb wu
kb presses 100 reps each arm with out setting it down. I used the 53 and took 12:23, sarah used a 20 and finished a few minutes before me. we did rest a time or two with the kb on our shoulder.
then did sled pulls forward and back
grip junky
Post by grip junky » Wed Feb 29, 2012 5:40 pm
2/27/12
cb warm up
med ball throws 30lbs 87throws, 12lbs 20throws
2/28/12
farmers walk
112lbs 2trips 217lbs 2trips
barbell clean and press
147lbs 1set 3reps 167lbs 1set 3reps 187lbs 2sets 3reps 187lbs 1set 1rep
kb front squat
70,53lbs 2sets 5reps 70,53lbs 2sets 5reps
underleg pass and swing
70lbs 4sets 5reps
grip junky
Post by grip junky » Fri Mar 02, 2012 5:45 pm
3/1/12
cb wu
high bar squat
147lbs 1set 3reps 237lbs 1set 3reps 274 1/2 3sets 3reps
tire flip
850lbs 5sets 2reps
kb clean no swing
88lbs 10sets 3reps
dips
bw 5sets 3reps
grip junky
Post by grip junky » Mon Mar 05, 2012 5:46 pm
3/3/12
threw outside shot, lt weight, pud and hammer
3/4/12
cb wu
kb overhead walk
88lbs 4trips
kb front squat
70,53lbs 2sets 3reps 53,70lbs 2sets 3reps
kb swing
88lbs 5sets 5reps
rope pull ups
bw 5sets 3reps
db one arm bench
70lbs 3sets 8reps
grip junky
Post by grip junky » Tue Mar 06, 2012 5:49 pm
3/5/12
cb wu
med ball throws
30lbs - 109 throws
20lbs - 15throws
grip junky
Post by grip junky » Thu Mar 08, 2012 5:40 pm
3/7/12
farmers dl
217lbs 1set 3reps 267lbs 2sets 2reps 287lbs 2sets 1rep 217lbs 2sets 3reps
147lbs 1set 3reps 177lbs 1set 3reps 197lbs 3sets 1rep
lifeline power wheel walks
the power wheel walks i counted as a carry(my bw), the clean and press was my pull/push and the farmers dl a squat. last night when I was doing them i thought of it as a hinge as well. after thinking about it i was wrong on that one,so i will pick up a hinge tonight. I had more on the 197lbs press but I did not want to jump to fast so i will work up to 3 reps over the next 2 times.
grip junky
Post by grip junky » Tue Mar 13, 2012 4:45 pm
3/8/12
cb wu
ghr bw 8sets 5reps
med ball throws 30lbs -111 throws
3/10/12
Billy yes we trained
Did a medley ran through it 3 times had about 8 to 10 minutes rest between
farmers walk 152 each hand
sled drag backword 135lbs
ring push ups 5reps
hammer strikes 20lbs 10reps
sled drag forword 135lbs
As I look at this medley I do not think it looks that hard, but it kicked my ass.
3/11/12
threw heavy weight and pud
grip junky
Post by grip junky » Thu Mar 15, 2012 4:43 pm
3/13/12
cb wu
loch norman stone lift (with a squat)
175lbs 8 trips
at loch norman they start a stone between 2 barrels about 8' to 10'on each side, you pick up the stone carry it to one barrel set it down carry it back to the middle set it down pick it back up carry it to the other barrel set it down then carry it back to the middle. That is on trip I added a stone squat on each pick up and set down.
ring dips
bw 1set 3reps bw 4sets 2reps
kb cleans 88lbs did them for about 15 minutes not sure of the reps I did rest .
grip junky
Post by grip junky » Fri Mar 16, 2012 4:34 pm
3/14/12
threw shot about 15 throws with the 12lb and 15 with the 16lb and then back to the 12lb for 10 throws
3/15/12
cb wu
barbell highbar squats
147lbs 1set 3reps 237lbs 1set 3reps 277lbs 3sets 3reps
ghr
bw 10sets 5reps
kb clean and press
88lbs 1set 1rep 88lbs 1set 2reps
same
same
same
same
grip junky
Post by grip junky » Tue Mar 20, 2012 4:41 pm
3/17/12
threw pud, heavy weight and shot
3/18/12
cb wu
sand bag carry
175lbs 4trips
jump squats
bw 5sets 5reps
wheel roll outs
bw 5sets 5reps
kb high pulls
3sets 5reps
super set db one arm bench then med ball chest throw (got this from some where on here)
db bench 70lbs 5reps/medball 30lbs 5reps for 5sets
3/19/12
threw hammer
grip junky
Post by grip junky » Thu Mar 22, 2012 4:37 pm
3/20/12
tire flip
850lbs 5sets 3reps
ring rows (I tried them because the crossfit girl was yapping about them, I did not like them)
bw 5sets 5reps
super set dips and med ball chest throws
dips bw 5sets 5reps
med ball 30lbs 5sets 5reps
3/21/12
threw pud
grip junky
Post by grip junky » Fri Mar 23, 2012 4:37 pm
3/22/12
cb wu
farmers walk
112lbs 2trips 222lbs 2trips
kb front squat
70,53lbs 2sets 5reps 53,70lbs 2sets 5reps
ghr
bw 5sets 5reps
kb clean no swing
115lbs 5sets 2reps
ring push up
bw 3sets 5reps
grip junky
Post by grip junky » Tue Mar 27, 2012 4:41 pm
3/24/12
threw 42 and 28
3/25/12
cb wu
we fooled around with my new sled
kb two handed swings
115lbs 5sets 5reps
over head kb carrys
70,53lbs 3trips 53,70lbs 3trips
we fooled around with pull ups
3/26/12
cb wu
I wanted the amount of throws up so I started with med ball throws 30lbs 65throws
highland hammer
22lbs 15throws
I would say only about 8 or 10 good ones
grip junky
Post by grip junky » Wed Mar 28, 2012 4:37 pm
3/27/12
cb wu
high bar squat
stone pics and carry
6 trips
super set ring push ups and bed ball push throws
ring push up bw 5sets 5reps med ball 30lbs 5sets 5reps
kb hang cleans 88lbs 3sets 5reps 88lbs 2sets 3reps
A friend dropped by last night to check out my sled. His words it is "fucking bad ass for 119". The best part is he is going to let me use a 40lb med ball he has.
grip junky
Post by grip junky » Fri Mar 30, 2012 4:44 pm
3/29/12
cb wu
farmers dl
222lbs 1set 3reps 252lbs 1set 1rep 292lbs 2sets 1rep 252lbs 1set 4reps
sandbag carry
170lbs 2trips
ghr
bw 5sets 5reps
kb clean and press
grip junky
Post by grip junky » Mon Apr 02, 2012 4:40 pm
4/31/12
threw sheaf, shot and pud
4/1/12
rode bike to gym
punching bag wu
medley
sled push 1trip (up and back)
wheel rollout 5reps
sled push 1 trip
ring row 5reps
sled push 1/2 trip
med ball up and over head throw 30lbs 3reps
We did this 3 times I went 1 time through then she went then I went and so on. I shoe gooed some soling leather to the runners on my sled. It made it a lot harder to push.
rode bike home
grip junky
Post by grip junky » Wed Apr 04, 2012 4:50 pm
4/2/12
threw 16lbs stone and lt for distance
4/3/12
stone pics and squats
175lbs 5sets 3reps
hypers
bw 6sets 8reps
kb over head carry
70,53lbs 1set 1trip 53,70lbs 1set 1trip
147lbs 1set 3reps 177lbs 3sets 3reps
med ball push throws
4sets 5reps
grip junky
Post by grip junky » Thu Apr 12, 2012 5:01 pm
I do not know why I have not been keeping up with this, I have not been over here that much. Training has been going very good. I have games coming up, 4/14/12 doing something with Dave Strunk games or demo not sure. I hope demo. 4/21/12 is Loch Norman I want to go very bad, I have been training like I am but not sure about the cash. I am in at Triad on the 28th ( that might not be the date) but I am in. 6/2/12 I have Laurel hill.
Just some thoughts, not sure why I am putting it here. I am not going to get into the Highland game gossip. But there was a group of women who killed the womens games down here. They cut back on womens games because of them, and stopped letting some come and throw and calling it a demo. The best way to get women back into the games down here is if they are willing to let you hang out and throw as a demo, is to show up and do the demo. A demo is a full games you just do not get your scores post at NASGA.
grip junky
Post by grip junky » Tue Apr 17, 2012 4:59 pm
4/14/12
My first games demo went well. took our three games throws and then threw that event as much as we wanted. I took a lot of throws. Strunk did not seem to be as stressed about time and junk so he was big on the tips. Now I am going to sound like rant. I weighed on friday and was at 208, that is about where I was at my last games last year. I knew that the top of the back of my legs and the bottom of my butt were bigger but I did not know that my waist had got a good bit smaller. To make my kilt so it would not fall down the first hunk of velcro went well past the end. The 2nd strip of loop had to attach to the 1st strip of hook. Their is a good 3 to 4" flapping around. My belt has been 2 holes in but I just did not think about it.
4/16/12
threw my 175lbs stone across the park and back it took about 35 minutes. 14 throws across slight up hill and 8 back. then I did about 5 stone squats.
grip junky
Post by grip junky » Thu Apr 19, 2012 4:35 pm
4/17/12
cb wu
med ball throws
30lbs 92 throws
fooled around on the peg board and sled pushes
4/18/12
farmers walk
112lbs 1trip 222lbs 4trips
kb cleans no swing
88lbs 5sets 5reps
jump squats
bw 5sets 5reps
kb two hand swing
88lbs 5sets 5reps
grip junky
Post by grip junky » Fri Apr 20, 2012 5:09 pm
4/19/12
cb wu
kb over head carry
70,53lbs 2trips 53,70lbs 2trips 88lbs 1trip
ghr
bw 7sets 5reps
kb front squats
db bench one arm
85lbs 3sets 3reps
med ball push throw
30lbs 3sets 3reps
