Enchiridion
Re: Enchiridion
Post by odin » Fri May 30, 2014 6:12 am
29/05
1. meditation
2. joint mobility routine
3. climbing - 2 hours worth of bouldering and some top-roping
30/05
1. meditation
2. bar complex x 3
3. Military press - 45kg x 12
4. FSQ - 95kg x 9
5. RDL off blocks - 100kg x 2 x 10
6. DB press - 30kg x 12
7. Pulley row - 66kg x 11
8. DB curls - 18's x 8
finished with some TGU's and swings, easy.
I used 5's to warm up, but did more sets and it worked better. However, working near failure in the squat is not good - your form goes to shit and it doesn't feel good on those last reps. Need to leave a few in the tank if I return to this template post-holiday.
Re: Enchiridion
Post by odin » Sun Jun 01, 2014 8:41 pm
01/06
1. meditation
2. foam roll & stretching in evening
Re: Enchiridion
Post by odin » Mon Jun 02, 2014 7:07 am
02/06
1. meditation
2. JM & snatch complexes with bar to warm up
3. Power Snatch from hang+OH Squats - 1+5, sets from 30 to 45kg
4. FSQ - 7 sets of 5 waved from 70-90kg
5. Power clean and push press -1+5, 6 sets waved from 40-60kg
6. chins - sets of 5, supersetted with above
7. KB swings - 20kg x 100 reps
8. grappler machine - 2 sets of 1 min
Way better way of training. Fun stuff is important. Basic, sub-maximal athletic strength work followed by some fun conditioning is the way forward.
