Training Log
greenghost
Post by greenghost » Thu Mar 01, 2007 8:37 pm
Thanks Mickey,
Just to be clear, that was a 2 handed drill and not 1.
PSST....it's easier than ya think. Nice compliment to Swing Snatches ! Try them.
" Once You've Walked Through The Fire Unscathed, Nothing Else Can Ever Burn " USMC
Post by Mickey O'neil » Thu Mar 01, 2007 8:54 pm
I'll give it a try. Need a heavier bell though, don't think a 53 would do me any good.
greenghost
Post by greenghost » Fri Mar 02, 2007 2:34 am
Weighted CG Chins done for 5 sets of singles. 100, 120, 135, 120, 100.
Weighted CG Chins done using 100 lbs of chain weight for 1 set of 10 reps.
Resistance at the bottom = bodyweight , halfway = bdy + 50, at top bdy + 100. Awesome feel.
Tomorrow - Push Day.
greenghost
Post by greenghost » Fri Mar 02, 2007 11:22 pm
Push Day Noon
2 DB Shoulder Lateral Warmup Drill - ( rear,side,front ) 25s done for 3 sets of 15 reps.
2 DB Floor Press done using 120s for 5 sets of 2 reps.
Tonight
2 DB Seated Presses done using 50s for 8x8. ( rep day ) 60-90 seconds rest between sets.
Weighted Pushups done using 45 lb Plate for 1 set of 30 reps. Happy with this.
Off Tomorrow, More Non-Organic Red Meat Tonight ! hahaha
Post by Mickey O'neil » Sat Mar 03, 2007 2:06 am
greenghost wrote:2 DB Floor Press done using 120s for 5 sets of 2 reps.
Any problems getting the dbs into position? Those are some heavy ass dbs!
greenghost
Post by greenghost » Sat Mar 03, 2007 2:51 pm
Mickey,
The DBs were handed to me by training partner. This drill won't be a keeper.
I hate partial movements!
Post by Mickey O'neil » Sat Mar 03, 2007 2:59 pm
I keep forgetting you train with someone. For some reason I always thought you trained alone.
greenghost
Post by greenghost » Sun Mar 04, 2007 11:08 pm
Mick, 99% of the time I do train alone.
eddie
greenghost
Post by greenghost » Sun Mar 04, 2007 11:20 pm
Today - Pull Day, Noon -
1 set of Dead Cleans using 2 90 lb KBs for 1 single. ( test )
KB Dead Clean / High Pull Complex done for 10 sets of 3/3. ( 6 total reps per set ) For Dead Cleans I used 2 75 lb KBs and for the High Pulls I used 1 150 lber. As Follows.
3 Dead Cleans with 2 75 lbers and 3 High Pulls with 150 lber = 1 superset . No rest between the Dead Cleans and High Pulls. . 6 pulls total for each set, and 60 seconds rest between sets. Great Combo Drill. using both a side pulling action and a center pulling one. A definite keeper!
Tonight -
CG Chins done using 90 lbs for 3 sets of 6 reps.
CG Chins done using 45 lbs for 1 set of 15 reps.
Tomorrow Push Day.
greenghost
Post by greenghost » Mon Mar 05, 2007 11:22 pm
Push Day - No noon training
Tonight :
Suspended Weighted Dips done using bodyweight + 115 lbs for 5 sets of 2 reps.
Fixed Bar Dips done using bodyweight + 90 lbs for 1 set of 10 reps.
Finished with 2 DB Decline Ext. using 50s for 3 sets of 8 reps. Slight pause at the bottom of each rep.
Off tomorrow and after that for 3-5 weeks I'm going to follow an every other day training protocol. ( 1 On , 1 Off ) Will start going heavy on Dips and make it the main Pressing movement of my program. Other training will be added on off days.
Bodyweight @ 176 this morning. Big Porterhouse Tonight ! Hope it's laced with hormones! LOL!
greenghost
Post by greenghost » Thu Mar 08, 2007 7:20 pm
Tuesday - Off
Yesterday - Pull Day
Noon:
KB Double Dead Cleans done using 70s for 5x5. 45 seconds rest between sets.
Deadlifts done as follows - 405 x 1, 455 x 1, 495 x 1, 405 x 5.
Evening:
CG Chins done using bodyweight + 135 for 3 sets of 1, 1, 1,
CG Chins done using bodyweight + 90 for 3 x 3
Finished with bodyweight rev-hypers for 2 sets of 20 reps.
Today - Off
greenghost
Post by greenghost » Fri Mar 09, 2007 10:58 pm
Yesterday - Off
Today - Noon:
Fixed Bar Weighted Dips done using bodyweight + 155 lbs for 7 sets of singles. 4 weeks ago I did 150 for 5 singles .
Suspended Weighted Dips done using 100 lbs for 3 sets of 5 reps.
Evening:
2 DB Overhead Presses done using 70 lbers for 3 sets of 5 reps.
Finished with Suspended Weighted Pushups using 70 lbs for 2 sets of 15 reps. Feet elevated higher than hands by about 18 inches.
Day on, day off training is paying off already due to extra rest !
Tomorrow training some SWAT buddies. Rib Roast tonight ! Still zero carbing. Meat + Fat is where it's at !
greenghost
Post by greenghost » Sun Mar 11, 2007 11:39 pm
Yesterday - Off
Today - Noon
KB Swing High Pulls done using 210 lber for 6 sets of 3 reps. ( front pull drill )
( I used my 150 lber + 60 lbs of chain ( fixed weight ) attatched to each side of the handle using flex cuffs ) Future drills will be done using KBs attatched to the handles. Got many KBs so the combinations are endless.
Finished with 1 set of TBDLs using 315 for 25 reps done touch n go. ( side pull )
Tonight -
Weighted CG Chins done using 80 lb DB for 5x5.
Finished with 1 set of CG bodyweight chins for 20 reps.
Off Tomorrow, Time to eat meat !
greenghost
Post by greenghost » Thu Mar 15, 2007 10:57 pm
Mon. Off
Tues. Push Day
Noon,
2 DB Overhead Presses done using 75s for 5 sets of 3 reps
JS 2 Mini-Band Presses done for 1 set of 25 reps.
Evening
Weighted Fixed Bar Dips done using extra 90 lbs for 6x6.
Weighted Pushups done with 45 lb plate for 1 set of 25 reps.
Wed. Extra Workout.
KB Swing High Pulls done using 150 lber for 10 sets of 5 reps. 30 seconds rest between sets.
Thur. Pull Day
Noon,
Dead Cleans done using 70s for 3 sets of 12 reps. All reps done touch n go without a pause or rest.
Evening,
CG Weighted Chins done using 120 extra lbs for 5 singles. Negtive portion on each rep took about 7 seconds each. 3 second pause at the top for each rep as well.
Finished with 1 set of Neutral Grip Chins for 20 reps.
Tomorrow Off. Still Zero Carbing and following a High Fat Plan !
Post by Mickey O'neil » Fri Mar 16, 2007 2:32 am
greenghost wrote: CG Weighted Chins done using 120 extra lbs for 5 singles. Negtive portion on each rep took about 7 seconds each. 3 second pause at the top for each rep as well.
You continue to impress. The 3 second pause at the top and 7 second negative is outstanding.
Eddie, I was curious if you have ever read the thread below from the low carb forum started by the guy who goes by "the bear". He is 70 years old and says he is in perfect health. He gives a very good argument about eating a totally carnivorous diet is the true way to eat. I believe it was discussed here a while back. If you have read over it I would like to get your thoughts, if you haven't read it no big deal.
http://forum.lowcarber.org/showthread.p ... arnivorous
greenghost
Post by greenghost » Tue Mar 20, 2007 10:10 pm
Mickey, Give a day or 2 too read that thread and I'll post a reply on the training forum.
Fri. Off
Sat. Push Day - Noon
BB Incline Press with Weight Releasers done using 285 lbs / 185 lbs for 6 sets of 3 reps.
Weight Releasers were loaded with 100 lbs and the negative portion was done using a very slow lower with 285 lbs. I then did 3 very fast reps with the 185.
Evening.
Fixed Bar Weighted Dips done using 100 lbs for 5x5.
1 set of bodyweight dips done for 20 reps.
Sun. Extra Workout.
Swing High Pulls done using 150 lb KB for 4 sets of 15 reps. Awesome !
Mon. Pull Day - Noon
KB Double Dead Cleans done using 80 lbers for 6 sets of 3 reps ( from the side )
Straight Bar Deadlifts done using 405 + 100 lbs of chain for 10 singles.
Evening -
Weighted CG Chins done using 90 lbs for 6x6.
Today Off , Tomorrow Push Day. Bodyweight @ 176 . More high fat hormone laced meat ! hahahaha
Post by Mickey O'neil » Wed Mar 21, 2007 1:17 am
That sounds great Eddie, I appreciate it.
In an essay on diet and exercise on his homepage he references a book called "Eat Fat and Grow Slim" and another called "The Cholesterol Myth" by Uffe Ravnskov. I looked up "The Cholesterol Myth" and it seems to be very interesting. I will probably pick it up at some point as well as the previous book mentioned.
Thanks Eddie!
greenghost
Post by greenghost » Sat Nov 10, 2007 12:10 pm
Yesterday's Training
1 Arm Swings done using 115 lb KB for 5 sets of 5/5.
All swings done to head level. Switch made on the fly.
Today's Training
15 minutes done on Elliptical Machine wearing 150 lb weight vest.
Brutal ! Wanted to quit after about 3 minutes but second wind kicked in.
Great feeling after I finished! Felt refreshed.
Been doing this for the past 6 months , although not with the same load.
I have an 84 lb X Vest and a 40 lb Go Fit Vest. I wore both and added extra 1 lb weights to the X Vest. I have 80 extra lbs on hand and have already loaded the vest to over 140 with no problems. This is the only quad dominant movement I can do because of knee problems.
Bodyweight has been between 170-180 all summer still eating high sat. fat meat only diet and following a IF protocal ( 22 hours between meals )
Tomorrow 2 DB Presses ! Will post more later.
Semper Fi ! Happy B-Day Jarheads.
Eddie
Post by Mickey O'neil » Sat Nov 10, 2007 12:22 pm
=D> =D> =D> The circle is almost complete! First ab g-d returns and now Eddie. All we need is Garm and the circle will be complete!
Welcome back GG! Where've you been? Just taking a break? You been doing alright?
Dazed
Post by Dazed » Sun Nov 11, 2007 11:27 pm
Welcome back GG!
I don't think you realize the depths of Jezzy's sexual greed~ EZ
Big, strong men (preferably in kilts) are my lesbian kryptonite~Jez
the right kind of male can make Jezzy's reproductive instinct overcome her preference for black vagina~Gary
greenghost
Post by greenghost » Mon Nov 12, 2007 7:16 pm
Yesterday Mid- Morning
2 DB Presses done using 65s for 5 sets of triples
Close Grip Chins done for 5 singles using 100 lb DB
Evening
Swing High Pulls done using 150 lb KB for 10 sets of 5 reps. 30 seconds rest used between sets.
Sometimes I do the high pull drill for 1 near max single set of 25 reps , 3-5 sets of 10-12 reps, or the above. This is the only high rep ballistic KB drill that I do.
My other 2 KB Ballistic drills are 1 Arm Heavy Swings and 2 KB Dead Cleans ( from outside the knees ) Nothing above 5 reps! Many ways to train with KBs. If it " works " for you , it can't be wrong !
Today
Elliptical Machine done for 20 min using 100 lb vest.
Tomorrow Weighted Pushups and Heavy Bag Drill.
Eddie
Sassenach
ironslinger
Post by Sassenach » Mon Nov 12, 2007 7:29 pm
You're back!
Kazuya Mishima wrote:they can pry the bacon from my cold dead hand.
grey
Post by grey » Tue Nov 13, 2007 2:24 am
greenghost wrote:If it " works " for you , it can't be wrong!
Truth. Welcome back greenghost!!
Training Log
Talk - Action = Shit
M Mahler
Post by M Mahler » Tue Nov 13, 2007 3:38 am
greenghost wrote:Yesterday's Training
Today's Training
Eddie
Interesting stuff with the elliptical machine and weight vest work. Nice example to thinking outside the box to work in a personalized leg program.
Shaun B. O'Murnecan
Post by Shaun B. O'Murnecan » Tue Nov 13, 2007 12:02 pm
Eddie
OK, I officially have a man-cunt now. That is incredible! What kinda injury, how long ago, blah blah.
Amazing shit!
