IGX "...overflowing with foulmouthed ignorance."
It is currently Sat Mar 23, 2019 10:48 pm
Post new topic  Reply to topic  [ 3 posts ]
Author Message
PostPosted: Sat Apr 05, 2008 2:44 am
Offline
Corporal
I found some of Steve Justa's singles routines posted on another board, thought I would pass them on.
Singles Strategy No.1 — One Lift
1. Lift every day, seven days a week.
2. Use 70% to start out and, as you gain strength, keep using 70%
3. During Week One:
• Day 1 – Do three singles with one to two minutes rest in between
• Day 2 – Do five singles with one to two minutes rest in between
• Day 3 – Do seven singles with one to two minutes rest in between
• Day 4 – Do nine singles with one to two minutes rest in between
• Day 5 – Do 11 singles with one to two minutes rest in between
• Day 6 – Do 13 singles with one to two minutes rest in between
• Day 7 – Do 15 singles with one to two minutes rest in between
You have now made a complete cycly and are at Week 2, Day 1. Now you will add five or 10 lbs and go through the whole cycle again.
4. Once a month, test your max to make sure you are using weights in your weekly cycle that are 70% of your max. If your weekly cycle weight was more than 70%, take weight off and adjust. If your weekly cycle weight was under 70%, add weight and adjust. This monthly testing of your max will keep you in the target zone.
This workout must be done seven days a week, 365 days a year. Each week, you are building your endurance and toughening your tendons and ligaments by doing more and more work towards the end of each cycle, and then during the next week, or cycle as I call it, you're adding more weight and doing it all over again. The great thing about this type of training is that you will build great strength without really ever making yourself tired because the body is adjusting naturally and rhythmically.
Singles Workout Strategy No.2 — One Lift
1. Lift every other day, seven days a week, 365 days a year.
2. Use weights that are 70% of your max.
3. Do 30 singles with between one and two minutes rest in between. When you reach a total of 30, you are done. Rest a day. Then add five lbs the next workout and do 30 singles with one to two minutes rest in between. Rest a day. Add five lbs every other day, resting one day in between, and so on and so forth.
4. Then once every two weeks, max outand adjust your weekly poundage to make sure you are using 70% of your max. If you're using under 70%, add weight and adjust. If you're using more than 70%, take weight off to adjust. This will keep you in the target zone.
Singles Workout Strategy No. 3 — Three Lifts, eg. squat, bench press and deadlift
1. Lift every day, seven days a week, 365 days a year.
2. Do four singles in each lift with one to two minutes rest in between and go from one lift to the next quickly. Start with the squat, then go to the bench press, then go to the deadlift; use 70% of your max.
3. Add five lbs to your bench every three days; add 10 lbs to your squat and deadlift every four days.
4. Max out every three weeks in all three lifts. If using weights in excess of 70%, reduce weight to adjust. If using weights under 70%, add weight to adjust. This will keep you in your target zone. Concentrate on speed when performing the lifts during your daily workouts.
Singles Workout Strategy No.4 — Three Lifts eg. squat, bench and deadlift
1. Train every other day, seven days a week, 365 days a year.
2. Train Bench Squat, Bench Deadlift, Bench Squat, Bench Deadlift, every other day, so on and so forth.
3. Do 25 singles with one or two minutes rest between each single in the deadlift and the squat and do 12 singles in the bench on each squat and deadlift day. For example:
Mon – squat 25 singles, bench 12 singles
Tues – off
Wed – deadlift 25 singles, bench 12 singles
Thurs – off
Fri – squat 25 singles, bench 12 singles
Sat – off
Sun – deadlift 25 singles, bench 12 singles
4. Every week add 20 lbs to your squat and deadlift and 10 lbs to your bench.
5. Every month, max out in each lift and if the poundages you're using in your weekly workouts are over 70%, decrease weight to adjust. If the weight is under 70%, add weight to your weekly workouts and adjust. This way you stay at your target weight of 70% max in workouts.
Singles Workout Strategy No.5 — 10 to 15 Lifts
1. Work two days on, one off, seven days a week, 365 days a year. Work all 10-15 lifts on each day.
2. Do two singles in each lift with one to two minutes rest in between each lift and for each single use 70% of your max.
3. Add five to 10 lbs to each lift every three days.
4. Every two weeks max out in every lift; adjust all weights in your daily workouts to 70% of your max in each lift. The day that you max will be your workout for that day.
Singles Workout Strategy No. 6 — 30 to 40 Lifts
1. Work every other day or once every three days depending on how you feel. Do all 30-40 lifts in one workout.
2. Do one single in each lift, moving from one lift to the next every two to three minutes. Use 70-85% of your max.
3. Add five to 10 lbs to each lift once a week.
4. Max out on all lifts once a month; then adjust all lifts to fit between 70 and 85% of your max on each lift. This will keep you in your target zone.
PostPosted: Sat Apr 05, 2008 12:29 pm
Offline
I wonder why he figures every other day workouts need like 5x the volume? :-k
PostPosted: Thu May 24, 2012 1:24 pm
Offline
Any IGXers had success with Justa's singles routines? I did strategy 1 a LONG time ago and got nothing out of it. I was really into singles back then. Heavy singles worked for me, but using 70% didn't work for me.
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 6 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Limited
